Window Felt Seal
Window Felt Seal
Have a horrible draft coming from the passenger rear window...quite loud at highway speeds. I finally investigated it today and for some bizarre reason the felt that surrounds the window in the frame is missing several inches...I suspect this is my culprit.
I checked a couple of sites and I haven't turned anything up...anyone know what I should do about this? Is there a source for original equipment or replacement felts or am I left trying to rig something up to stop the draft.
I used the window to slide mine back up. Going up with the window, grabbing onto the little I left showing, going down, letting go, going back up, etc. I glued it back in place with some kind of black window adhesive I got at Auto Zone. I think that was about 2.5 years ago and it's still holding.
Stick a screwdriver in the felt trim, push in and up and it will slide back to the original position.
