Window Felt Seal
Old May 10, 2008 | 08:05 PM
unstable's Avatar
Default Window Felt Seal
Have a horrible draft coming from the passenger rear window...quite loud at highway speeds. I finally investigated it today and for some bizarre reason the felt that surrounds the window in the frame is missing several inches...I suspect this is my culprit.
I checked a couple of sites and I haven't turned anything up...anyone know what I should do about this? Is there a source for original equipment or replacement felts or am I left trying to rig something up to stop the draft.
Old May 11, 2008 | 06:18 AM
jskrebs's Avatar
Default RE: Window Felt Seal
On my 99 the strip slid down the rear track about 2". I pulled it up, swabbed the rubber and inside of the track with alcohol and then glued the strip with RTV. Holding fast a year later.
Jeff
99 D2
Old May 11, 2008 | 11:56 AM
unstable's Avatar
interesting thought...I'll take a look at that...that'd be a nice, easy, cheap fix and I wouldn't have to wait for or locate parts.
But just in case...does anyone have a source for the window felts?
Old May 11, 2008 | 01:17 PM
unstable's Avatar
GREAT TIP JEFF! That worked like a charm! I was able to reach in and pull the felt up the track. I need to get some weatherstrip adhesive to really tack it in, but otherwise that's awesome.
Old Sep 19, 2017 | 03:49 PM
Kngsxvigil's Avatar
Default Window Felt/trim rear channel slid down
Jeff, or anyone who's had this same problem: How did you "grab" the trim to slide it back up? I have the same problem on my right rear door, AND to a lesser degree on my left rear door.
Thanks in advance.
Mark
Old Sep 19, 2017 | 05:12 PM
04in719's Avatar
When this happened to me I found a bunch of it at a local pull and pay from a D1 and D2, grabbed several feet of it from a couple windows for the future.
Was about 4 bucks. Took some elbow grease to install but was well worth it.
Old Sep 20, 2017 | 10:40 AM
Alex_M's Avatar
I used the window to slide mine back up. Going up with the window, grabbing onto the little I left showing, going down, letting go, going back up, etc. I glued it back in place with some kind of black window adhesive I got at Auto Zone. I think that was about 2.5 years ago and it's still holding.
Old Sep 20, 2017 | 02:44 PM
OffroadFrance's Avatar
TIP: the side window glass often breaks or drags the felt so periodically wind down the windows and spray the felt with silicon spray preferably through the straw they provide.
Old Sep 22, 2017 | 08:47 AM
nickm347's Avatar
Thanks in advance.
Mark
Stick a screwdriver in the felt trim, push in and up and it will slide back to the original position.
jmeezie
Detailing
Oct 6, 2013 07:07 PM
tsuami1
Jul 24, 2012 10:33 PM
tsuami1
Jun 20, 2012 10:20 PM
MojaveMike45
Oct 2, 2009 05:06 PM
DuplinDisco
Feb 4, 2008 06:30 PM
