Freelander Talk about the Land Rover Freelander within.
Blower motor,i need help!
Old 02-23-2013, 06:54 PM
JAIMELU's Avatar
Default jaimeluciano
Originally Posted by jerellmorse
my 03 freelander heat and air stoped work for awhile it would work every now and then and it would smell like burning wires i took alook at the blower motor and it was covered in a red sticky stuff any ideas? i've look around for a new one and it seems most of what i have seen is around 400 bucks it looks like it would be easy to replace anyone have the same problem that can help?
jm, tell me how old is your flander, may be you have to replace the thermostat assy, Ive seen this problem very often. Nobody wants to do it ,cause is located in back of engine ,and very hard to work on it.
Old 02-23-2013, 07:02 PM
JAIMELU's Avatar
falks, I´m working in a freeldr, 2.5 v/6 2004 , need specs, and engine overhaul diagrams and specs. if someone can help, I´m a fun of other land rovers,but this is a real challenger, customers think I´m a land rover doctor, but this is a real challenger
Old 02-23-2013, 07:10 PM
JAIMELU's Avatar
land rover best 4x4 by far, nice slogan, In puerto montt , chile, not too many garages, know land rovers as I do, at first in canada and lately in the falklands,
graet experiences, To a land rover owners , if I can help will be glad to
jmj
tel 82435904
Old 02-23-2013, 08:15 PM
JAIMELU's Avatar
Default jaimelu
i've been looking threw all these forms and am reading alot of bad things about these freelanders do you think i made a mistake should i trade it in?
Freelds are great vehicles but like everything else you have to take care about the engine you are buying, best of all are the td4 turbodiesel german bmw
also isthe 1.8 land rover td engine . There also 1.8 16 valve petrol which is pretty goog.
Old 02-23-2013, 09:22 PM
JAIMELU's Avatar
Not really depends on the engine you have. Let me know whats your problem
Old 02-23-2013, 09:33 PM
JAIMELU's Avatar
i THINK YOU HAVE A BAD HEATER MOTOR, FIND AN AFTER MARKET ONE , IN UK IT´LL BE AN EASY JOB,
Old 02-23-2013, 09:56 PM
JAIMELU's Avatar
depend on the type of engine you have, most of makes recomend tbelts every 75.000 km,
Old 02-27-2013, 10:26 AM
rtonder's Avatar
You can download the RAVE (PDF version of the factory repair manual) from a sticky in the D2 forum. This will give you the technical information, and it will also reference the special tools needed to pull the heads. They are not that sophisticated, and can be purchased on EBay UK if you do a search.
In general, the engine's greatest bugaboo is overheating which causes the heads to push the liners into the block. After that point, they will no longer seal, and cannot be made to seal, without restoring the liner deck height above the block. I have developed a way to lift the liners using a shim, but it is no small amount of work.
I've run the repaired engine hard and it is holding well after 10k miles.
Old 02-28-2013, 06:10 AM
JAIMELU's Avatar
Hei chap, youhave to remove the heater motor, clean it on the bench an try it if is goos whith a goo source of 12volt power, , Second check youre heater core. could be leakink,
but if that hapened , should be coolant on your floor carpet
blast20
02-10-2010 02:44 PM
wydell
06-11-2009 12:40 AM
willdisco99
07-09-2006 12:59 PM
deejax
07-05-2006 10:28 PM
eric2
05-28-2005 02:44 AM
Quick Reply: Blower motor,i need help!
