Freelander Talk about the Land Rover Freelander within.
Rear Window Recalibration
Old Jun 13, 2010 | 10:46 AM
jorge67's Avatar
7th Gear
Default Rear Window Recalibration
Hi i have a 2005 freelander i am having problem can not recalibrate rear window this happen after disconnected the battert any help will be very app. I have try the basicc repair but no luck yet .those any one know if the rear window has a sensor on the top ..
Old Jun 15, 2010 | 06:23 AM
Rovin4life's Avatar
if you disconnect the battery you should be able to go all the way and all the way down and it should calibrate. If it does not then something isn't working. You will need to take it to the dealer because we have to look at the status of the door and all of its components like the rear wiper, the switch status etc. And if everything is good and we can't calibrate it its possible the motor is bad.
twoxred
Oct 4, 2021 07:07 AM
Ghaniba
Jun 24, 2015 05:10 AM
Jedelmann
Feb 18, 2015 07:30 PM
jorge67
Freelander
Dec 19, 2010 04:50 PM
ljdiscovery
May 22, 2008 10:30 AM
