Hello,Help
sounds like a failed regulator, just like the windows, theres one for the tailgate too. its controlled by the ccu, so its most likely not a fuse, as the ccu wont allow it to draw more current then it should. i thing i would suggest as a shot before anything gets replaced, is disconnect the battery for about 15 minutes, and when you hook it back up and thurn the key on, the rear glass should roll all the way down. give it a shot
Speed racer
10-11-2008 10:56 PM
