Sponsored by: CARiD
Idling in neutral or park at 2000+ rpm.
Old Sep 2, 2012 | 01:34 AM
collin Barrows's Avatar
Default Idling in neutral or park at 2000+ rpm.
Hello, I’ve been having trouble with my Rover sputtering at traffic lights and stop signs. It only happens when she’s warmed up. Savannah Buzz suggested that I take a look at my vacuum hoses. I found one hose discounted (cruise control) but after reconnecting the hose my problem is still persisting on. She then started idling in neutral or park at 2000+ rpm. I’ve also tested most of my vacuum hoses (the ones that are easy to get to) and I don’t seem o have a vacuum. I'm not sure what’s going on. If anyone can suggest something I would appreciate it. Thanks.
Old Sep 2, 2012 | 09:53 AM
Draw the existing vac route. Find the hose that attaches to plenum or throttle body and attach old fashioned vac guage. Clean IACV and bore it fits into. Go from there.
Have you tested your coolant temp sensor?
Old Sep 2, 2012 | 11:47 AM
I cleaned/tested the IACV about a week ago, my dad has a vacuum gauge and I tested the vacuum from the distributor to the plenum chamber and it showed zero vacuum. I will go check the coolant temp sensor. That would make since because my temp gauge was showing that I was over heating but I knew I wasn’t over heating. My Rover has two temp sensors, which one should I check? How would I go about checking them? Thanks for your help.
Old Sep 2, 2012 | 12:36 PM
threalassmikeg's Avatar
Man.. You, and your Rover are having a bad week...
Check the flame trap in the passenger side valve cover. make sure it's not clogged
Check and clean the t fitting by the plenum on the drivers side.
Check and adjust your base idle w/ ac off. pinch off the hose that goes to
the stepper motor and set idle to around 700-800 rpm.
the idle bypass screw is on the throttle housing
release the clamp engine will rev up and maybe keep revving.
shut engine off and restart.
Idle should rev up and settle down.
Clear CEL using diagnostic plug under glove box.
plug in plug
turn on ignition
unplug plug from harness
count to 6
reconnect plug
count to 6 shut off ignition
repeat til codes are cleared
if codes don't clear you will ned to add a jumper wire into the plug
end of the harness
Try it
Good Luck
Old Sep 3, 2012 | 11:10 AM
plug in plug
turn on ignition
count to 6
reconnect plug
end of the harness
Try it
Good Luck
Thank you! I'm goig out to my Rover right now! I'll let yall know what I find out.
Old Sep 12, 2012 | 11:06 AM
YAY I fixed it!!!!!!! Turned out I had some mud on the fuel rail and the mud was insulating the rail. My other problem with my car bucking turned out to be a vacuum cap that needed to be removed. She still idles at 2000 sometimes; it’s a 50/50 chance of idling at 2000+ or 800....
MyRoversNameIsCarl
Nov 25, 2014 10:07 AM
eatmydollarsdisco
Jan 24, 2014 01:18 AM
willypilgrim
Dec 12, 2013 12:53 PM
mojosh
Sep 24, 2012 09:03 AM
alemurill
Dec 28, 2008 08:46 PM
