Sponsored by: CARiD
Gas Mileage Help for a 95 RRC
Old Jan 13, 2012 | 12:11 PM
livetoride's Avatar
Default Gas Mileage Help for a 95 RRC
I have a 95 RRC LWB with a 3" RTE lift and 255/85/55 BF Mudd Terrains and I am getting 10mpg. I wasn't expecting too much better, but is this normal and what are somethings I can do increase it? As of right now the top is bare so no rack or anything.
Old Jan 14, 2012 | 06:32 PM
You can remove the lift and put on less aggressive tires.
The more wind resistance the lower the MPG, so raise the truck and expose the axles and you reduce MPG.
Aggressive tread also increases rolling resistance which reduces MPG.
Old Jan 15, 2012 | 09:55 AM
livetoride's Avatar
It would take WAY too long to recoup the costs of lowering the truck. I'm not expecting to get amazing MPG, but I know people with similar lifts, larger tires and racks getting 4 mpg better than me.
Old Jan 15, 2012 | 12:19 PM
leadfoot's Avatar
Originally Posted by livetoride
I have a 95 RRC LWB with a 3" RTE lift and 255/85/55 BF Mudd Terrains and I am getting 10mpg..
How tall are those tires? The "55" does not make sense. The tire size will impact more than the lift itself.
Old Jan 15, 2012 | 01:24 PM
Is everything else OK on the truck? As an example, if your thermostat is stuck open, you won't overheat, but MPG will suffer. Same for some sensors.
Old Jan 15, 2012 | 03:42 PM
Some people I've learned on these forums really suck at math. They might not be taking into account odometer error from the tires etc. Also the terrain traveled will have an effect as well.
Old Jan 15, 2012 | 10:34 PM
Paul Grant's Avatar
Are you aware that when your Range Rover was brand new, traveling on skinny 205/85/16 tires, the EPA estimate for around town driving was estimated at 12 mpg. Now, 17 years later with significantly larger tires you're surprised with 10mpg?
I owned one of these LWB's back then when it was brand new. I seldom got better than the EPA estimates for around town and highway driving. They were pigs then and they're even worse today.
arains44
Nov 11, 2014 07:02 AM
nfamusrcr
Mar 19, 2014 09:21 AM
mossmanxjt
19
Feb 12, 2013 09:24 AM
MiniManiac
Nov 15, 2006 03:44 PM
dogstarsix75
Apr 23, 2005 11:21 AM
