Sponsored by: CARiD
Three Chimes at random intervals..
Old Feb 17, 2012 | 10:20 PM
Kingmarine's Avatar
Default Three Chimes at random intervals..
Just got this 2003 Disco II and managed to get it to hold its oil so far. Now I'm trying to get the vehicle to stop chiming at me. All lights work and none are on. Random 3 chimes at no specific interval. 2003 model so no CDL.
I did search and see where others have had similar issues but no report as to what actually resolved the issue. Any help is greatly appreciated.
Old Feb 18, 2012 | 07:11 AM
Do all of the dash warning lights work?
Example, when you turn the key to the "run" position but do not start it do the check engine light, traction control, ABS, etc. lights come on?
Old Feb 18, 2012 | 12:15 PM
Kingmarine's Avatar
Yes, I double checked this morning. All the lights that are supposed to come on when the key is moved to the run position do.
Old Feb 18, 2012 | 01:22 PM
Is the SLS still there or has it been converted to coil springs?
Old Feb 18, 2012 | 03:45 PM
Kingmarine's Avatar
Good question, didn't think of that. It has coils, but I assumed SLS was not included on this model. How would I be able to tell if SLS was on this vehicle originally?
Old Feb 18, 2012 | 04:01 PM
If it is a 7 passenger it came with the SLS, no other option.
It was included to aid in getting in and out of the back by lowering it.
So....look for the height sensors on the rear axle, the compressor under the passenger floor board.
Then do this test, drive it hard around a corner so it leans, does the chime go off?
If the system is not turned off and there is a fault if I remember right it chimes at you and sets off a warning light.
The light is of the back of the truck with a arrow pointing down if I am not mistaken.
That bulb could be broken and I think it is supposed to come on during the self test when you turn on the key, but I could be wrong.
SO, if they replaced the SLS but did not take it to the dealer to have it turned off it will set off a fault code (SLS warning lamp) when it detects a fault, like the truck not sitting level, etc.
Old Feb 19, 2012 | 09:02 AM
Not all SE7's came with SLS. The easiest way to tell if yours had it would be to look at the switches to the right of the cluster and see if there is one showing the back of the truck with an arrow pointing up.
Old Feb 19, 2012 | 10:35 AM
Thank you for the correction Mike.
Old Feb 19, 2012 | 04:28 PM
Kingmarine's Avatar
I have double checked now to verify and I do not have that switch with the arrow pointing up.
Charliebearuk
Apr 19, 2012 06:25 AM
DSCVRY
Jan 25, 2012 07:26 PM
FightOnUSC79
Apr 6, 2011 08:46 PM
04BluDisco
Jan 23, 2010 04:24 PM
Spike555
Oct 3, 2009 09:34 AM
