Sponsored by: CARiD
please help with codes
Old Feb 14, 2012 | 09:08 PM
parksy's Avatar
Default please help with codes
I had my diagnostics plugged in to help with m and s lights and they came up with " cams time out " and " can time levelling " anyone know these as I dont want to waste more money
Old Feb 15, 2012 | 04:20 AM
Those would be CAN codes (don't be dragged to another area by "cam") -
From the RAVE:
Software in the EAT ECU monitors hard wired inputs and exchanges information with the ECM on a Controller Area Network (CAN) bus to determine gear shift and torque converter lock-up requirements. Resultant control signals are then output to the gearbox solenoid valves.
Those codes are from the tranny ECU, which talks to the main ECU constantly over a network. So you are probably in limp home mode, poor shifting, etc. Could be module, grounds near it, voltage problem (battery needs to be 100%), wiring issue, etc. Not sure if XYZ switch full of water and mud could do it, but you can check that for grounds also when under the truck with a meter. Basically the tranny ECU is having a hard time hearing the main ECU.
RAVE has color coded wiring diagrams, and here are a couple of pages that describe the codes and the info that the transmission finds to talk about with the engine computer constantly.
File Type: pdf
File Type: pdf
Old Feb 15, 2012 | 10:22 AM
What are the exact fault code numbers, this will help us help you.
Old Feb 15, 2012 | 11:02 AM
If they are 1842 and 1843, those are CAN error codes for the transmission, and have text message that is similar to your post.
NWROVERS
Mar 10, 2015 03:17 PM
csp
Jul 1, 2013 07:33 AM
buick56
May 15, 2013 06:11 PM
04SSHD
Apr 11, 2012 06:20 PM
BajaXJ92
Dec 3, 2009 07:43 PM
