Sponsored by: CARiD
Fuel Pump Fix
Old Jul 7, 2011 | 03:12 PM
bsears11's Avatar
Default Fuel Pump Fix
Alright, here's the shot. I have a 1999 Discovery SD that I need to replace the fuel pump on. I've found some on eBay for a reasonable price that I need to choose from. So a few questions:
1) is there certain specs I'm looking for?
2) where is the fuel pump located? is it in tank? can i just remove my rear seats and get to it from inside the truck. or lower the whole tank down?
I'm not a huge mechanic so maybe someone has the best idea as to do this whole process.
3)any help tips, ideas, as far as what i need to do for this job would be appreciated!
Old Jul 7, 2011 | 03:20 PM
Chris-bob's Avatar
Is it a Disco 1 or 2? Disco 1 pump is $100 from Rovers NorthLAND ROVER PARTS - FUEL PUMP/SENDING UNIT RANGE ROVER & DISCOVERY
and D2 w/secondary air $345 LAND ROVER PARTS - FUEL PUMP/SENDER ASSEMBLY DISCOVERY II
and D2 w/out secondary air $380 LAND ROVER PARTS - PUMP - FUEL TANK UNIT DISCOVERY II
You access it from the cargo area under the carpet. Do a search and you will find many pictures of the install.
Old Jul 7, 2011 | 04:27 PM
bsears11's Avatar
Not sure if its a disco 1 or 2 or if it has secondary air or not. how can i find out? lol i sound like an idiot i'm sure
Old Jul 7, 2011 | 06:10 PM
Chris-bob's Avatar
Does it say Discovery II on the back? What was the month of manufacture? I have no idea regarding secondary air because I have a DI
Old Jul 7, 2011 | 08:14 PM
Rovin4life's Avatar
Do you know if it needs a fuel pump or are you guessing?
Many a time the crankshaft position sensor will cause the problem.
Old Jul 7, 2011 | 08:45 PM
Might want to download that RAVE service manual, it shows tests, and how to do the job. You might not need a pump, could be a $15 fuel filter blocked up. You can rent or loaner a fuel test gauge from a parts store, it will screw right onto the valve on the fuel injector rail, should build up and show 32-36 PSI when key is turned to running position. Have rag ready for any fuel squirt spill.
Old Jul 7, 2011 | 08:53 PM
Is your odometer digital or mechanical?
If it is mechanical then you have a DI.
Old Jul 7, 2011 | 08:54 PM
Old Jul 7, 2011 | 08:57 PM
Thats the wrong fuel pump for a '99 DI.
Late '97 model year the advanced evap loss system was introduced, this bumps the price of the fuel pump alittle.
LAND ROVER PARTS - TANK UNIT - FUEL PUMP / SENDER
Old Jul 7, 2011 | 10:28 PM
Chris-bob's Avatar
Ahh, I did not realize that.
