Sponsored by: CARiD
will not start
Old Jun 26, 2013 | 08:19 PM
Joe34's Avatar
Default will not start
2000 Discovery II 4.0.
Water pump went out, then engine died.
Replaced water pump,engine would crank but willnot start.
Pushed inertia switch, to reset, but still willnot start.
Any help.
Old Jun 26, 2013 | 09:09 PM
How many miles on it, have you ever replaced the crank sensor, do you have a check engine light on and does it turn over, just not start?
Old Jun 27, 2013 | 09:04 AM
Joe34's Avatar
It has 95600 miles on it, I only have owned it for a year now.
So I do not know if the CPS has been changed or not.
It did get hot when the water pump went out.
Is there any way to check the CPS, to see if that is the problem?
Thanks again.
Old Jun 27, 2013 | 09:05 AM
Joe34's Avatar
Yes it does crank over, but will not start.
Old Jun 27, 2013 | 11:13 AM
Test for CKP sensor is bare spark plug, attach to existing plug wire, lay on manifold, watch for sparks when cranking. See attached.
If you get sparks, you can try a squirt (less than 1/2 second) of starting fluid into the throttle body (not the MAF). If starts on fluid, could be no or low fuel pressure.
File Type: pdf
Old Jun 27, 2013 | 03:22 PM
Joe34's Avatar
I tried the spark plug wire,with metal screw out of the plug boot against
metal manifold, cranking engine you get a spark.
Tried the starting fluid quick 1/2 sec. spray in to throttle body.
Still will not start.
Checked the fuel pump relay in under hood fuse block, it is OK.
Any more suggestions?
Thanks for the help.
Old Jun 27, 2013 | 11:14 PM
Joe34's Avatar
Could it be the security system, not letting it start?
How do I check that?
Any Help.
Old Jun 28, 2013 | 12:25 AM
The immobilization would make dash LED be on steady when key turned on, see page 1339 of the workshop manual..
Dryflyrod
Apr 23, 2014 06:02 PM
vtec2403
Jan 30, 2013 05:27 AM
Evan5291
Jul 26, 2011 06:06 AM
armyeng
Mar 8, 2011 05:58 PM
jonsimon
Jan 29, 2007 01:55 PM
