Sponsored by: CARiD
rust
Old Jan 9, 2012 | 07:06 AM
seasidenj's Avatar
3rd Gear
Default rust
I just bought a 1994 Discovery. Body is in very good shape the only rust I found is at the top of the rear wheel wells. Is this common? I plan to clean then epoxy rubber or something then undercoat.
Frank
Seaside NJ
Old Jan 9, 2012 | 08:04 AM
Depends on salt use or beach thong patrol in the past life of the vehicle. Near me, it is salty mud from the tidal swamps.
Suggest you search recent threads started by slanginsanjaun, he has posted pix of a complete rebuild of the rear floor pan with diamond plate aluminum, and a variety of special sealer and insulation, his was eaten away at just about all the corners.
Old Jan 9, 2012 | 08:33 AM
You will find this to be common, you should spend some more time under the truck cause there is most likely more rust there. As for treating it, need to be more agressive about totally removing the rust the treating or it will come back faster and worse then before.
Old Jan 9, 2012 | 07:01 PM
They all rust in that same spot, that is where the sheet metal underbody mates with the aluminum body skins.
When dissimilar metals touch they rust and corrode very fast.
albertwesker
Jul 4, 2007 04:49 PM
howellja
Apr 29, 2007 10:52 PM
sreuro
Dec 16, 2006 11:59 AM
Claree
Freelander
Apr 18, 2006 03:41 PM
bmwrovers
May 23, 2005 01:02 PM
