Sponsored by: DashLynx
Rear driver side brake sticking on Disco II
Old 09-23-2012, 08:41 AM
MntRover's Avatar
7th Gear
Default Rear driver side brake sticking on Disco II
I have a 2001 Discovery II with 108k miles. I noticed a burning smell last night after a 6 mile drive across town. Turns out the rear driver side brake is sticking and it was incredibly hot. Anyone had a similar experience? Where should I start with fixing this?
Old 09-23-2012, 08:52 AM
Replace caliper. My D1 did it on the passenger rear. I drove down the rural back road, and coasted to a stop in a safe area. Used my IR thermometer, and "shot" the temp of each brake disk. Should be same on each axle. The sticky one was 40 - 50 degrees hotter. Yours would have to be even hotter since you smelled it.
Calipers can be rebuilt, but only if caught very early, the bore will have been scored with any miles on it. Yours would not be a candidate for rebuild. I took one off a dead one in the boneyard.
Old 09-23-2012, 09:01 AM
MntRover's Avatar
7th Gear
Do you know of a good place to buy a new one online or elsewhere for a good price?
Old 09-23-2012, 10:20 AM
I got mine from AutoZone.
$75ea for the front and $50ea for the rear, thats for a DI though and they are larger calipers than on the DII so your I think will be cheaper.
Old 09-23-2012, 06:59 PM
Make sure to do a full 2 quarts DOT 4 brake flush and order some good pads, don't buy cheap ones or you will get the 3 amigos if you don't have them already.
Old 09-30-2012, 06:09 PM
MntRover's Avatar
7th Gear
Thanks guys. Turns out replacing the caliper and pads did the trick. You guys are great!
post42
09-10-2013 03:33 PM
grant99
11-10-2010 07:03 PM
Princess
09-15-2009 08:02 PM
jycsalas
07-18-2009 11:26 PM
BlueDisco
02-19-2007 02:50 AM
Quick Reply: Rear driver side brake sticking on Disco II
