Transfer Case - Paper Gasket or Hylomar Gasket
Hey All,
I have an '03 Disco 2 and pulled the transfer case last weekend, it was leaking pretty bad so I replaced all the seals and gaskets on her using a kit from Atlantic British. I purchased the Hylomar sealant as well but didn't think I needed to use it with the paper gaskets that came in the kit. Well here we are a week later and she is leaking out of the front output shaft bell housing where it seals to the transfer case housing. I can only imagine the leaks are going to get worse.
Should I just pour in some oil leak stop, or do I need to pull out the T-case again and re-do the seals using the Hylomar? or do I use the Hylomar and the paper gaskets together?
I would appreciate any advise you all have on this.
Thanks!
Thanks!
archaeology_student
08-02-2014 09:43 AM
