08 range sport supercharge hard starting
Check the fuel pump relay under the hood in engine compartment.
Switch it with one labeled SM(starter motor).
If the starter starts acting up you know it was the relay. I had similar issue, switched the relay and both starter and pump worked fine for months before selling the LR3(same basic system as a sport).
Thank you
QUOTE=abran;553764]Check the fuel pump relay under the hood in engine compartment.
If the starter starts acting up you know it was the relay. I had similar issue, switched the relay and both starter and pump worked fine for months before selling the LR3(same basic system as a sport).[/QUOTE]
alwezl8
01-10-2015 01:50 PM
GetFrosty
07-24-2012 08:43 AM
nextelsucks
Appearance & Camping Set Ups
05-18-2008 08:58 PM
nextelsucks
03-28-2008 09:25 PM
