Adding Factory GPS to 2008 LR 2/Discovery 2
Old 12-01-2016, 10:33 AM
LandRoverBob's Avatar
3rd Gear
Default Adding Factory GPS to 2008 LR 2/Discovery 2
I have a 2008 LR2 which I am preparing to sell. I can obtain a factory GPS unit off Ebay, which would make the car fully loaded. Not many 2008 had these as I understand there was production issue which delayed the option at the start of the model year, not sure if that is true. I have recently added the Factory Headset Video system. All the options I have added, had provisions for them in the wiring harness, so plug & play. Does anyone know if all connections and cables are in the dash to accept the GPS unit? These are sold by themselves with no cables. The vehicle has the Alpine Audio system.
Old 12-04-2017, 12:51 PM
riverwader's Avatar
5th Gear
Default LandRoverBob Adding Factory GPS to LR2
LandRoverBob did you find that all the wiring was there for the factory GPS off of eBay? I am interested in the same thing. Seems easy if the wiring is already there.
Old 12-04-2017, 01:16 PM
Received 1,465 Likes on 1,196 Posts
The connections are likely there but it is going to be a bit more than the screen portion. There is the exterior gps antenna etc that will be needed to function.
riverwader (12-04-2017)
Old 12-06-2017, 12:02 PM
SoCalLR2's Avatar
I installed a non factory but similar system in my 2009 LR2 HSE earlier this year. The connections were not there, nor was there a bracket for the GPS / DVD drive under the passenger seat. Fortunately, the system I purchased (also from eBay) had all of the necessary cables and connectors.
riverwader (12-06-2017)
Old 12-06-2017, 12:07 PM
riverwader's Avatar
5th Gear
Disappointing to hear that. I figured most of it would have been there.....
Old 12-06-2017, 12:12 PM
riverwader's Avatar
5th Gear
What system did you end up installing and did it come with everything to make the install? Was it an easy install? How long to make it happen?
Old 12-06-2017, 12:13 PM
SoCalLR2's Avatar
Your vehicle may be different. This was just my experience.
Old 08-31-2018, 04:46 PM
Keith G Hughes's Avatar
SoCalLR2,
I have the 2008 LR2 HSE and LR says the GPS was the same for the 2009... May I ask what system you found to install? Looking to do the same here.
Thanks,
Logan Kreider
LR2
05-19-2017 08:46 AM
LRtoo
LR2
06-20-2016 06:58 AM
EliFolsom
Audio/Visual Electronics
04-25-2014 05:21 PM
LandRoverBob
03-16-2014 04:00 PM
cl0r0x70
02-20-2011 03:15 PM
Quick Reply: Adding Factory GPS to 2008 LR 2/Discovery 2
