warning light?
Old Jan 10, 2010 | 08:54 PM
m1964's Avatar
Default warning light?
this morning (16F outside temp.) wife started the LR2, I came down 30 sec. later and saw red battery symbol on the dash. After the usual warm-up RPMs went down, and I started drivng -the light did not go off. Shut off the engine, re-strarted the truck -no problems, no more warning symbol, LR2 drove fine after that.
Anyone knows what it was?
thanx
Old Feb 27, 2010 | 09:41 PM
ScoobyD's Avatar
Hi I've had my LR2 for three days and this has happened to me. Have you had any more issues? thanks
Old Feb 28, 2010 | 10:40 AM
First, I would suggest you not do the warm up period you mentioned, this is very hard on an engine which is running full rich during the open loop/warm up period.
Start it, give it 30 seconds to 1 minute and go.
As for the fault code, I would suggest you find a shop that can read your battery/alternator voltage which should be between 13.6 and 14.4 volts.
cipher982
Nov 9, 2019 11:22 AM
mvjimenez
Jun 12, 2010 10:25 AM
steve c
Jan 26, 2006 09:55 PM
mcclellandm
Aug 9, 2005 05:54 PM
robdis96
Jan 30, 2005 08:45 PM
