SRS/Airbag Light Fix for 2010
Old Feb 3, 2014 | 03:37 PM
Pbpuckett's Avatar
5th Gear
Default SRS/Airbag Light Fix for 2010
SRS light wont go away and noting the numerous posts about a weak connection under the seat, Id like to dive in there and fix it. Problem is, I dont know which connection Im looking for. Ive removed the front panel of the driver side seat but cant seem to see anything that looks disconnected. Am I looking in the right place? Other posts say the disconnection is normal when the seat travels too much which would make sense since my wife is short and I am not. Thanks.
Old Feb 5, 2014 | 09:07 PM
Rover2013's Avatar
Passenger side seat sensor is bad I see these all the time u0154-00 if the fault code.
If you notice I this the dash area or up in the center console there is a air bag light off icon
If you sit in the passenger side seat with the vehicle running it should go out if not you know pretty much it's the seat sensor. There is a test that needs to be done to elemnate the body control module and wiring. Every time I do that test it brings me to that seat module sensor. Owe yea it's on back order.
mln01
Nov 14, 2019 07:15 AM
mike031
14
Nov 2, 2018 10:41 PM
Disco2001
Sep 4, 2011 12:13 AM
faversham
Jan 28, 2010 04:59 PM
NATEDOGG
Oct 14, 2009 03:27 PM
