Airbag fault srs light
Old Jan 26, 2010 | 12:45 PM
faversham's Avatar
Default Airbag fault srs light
Have 1996 P38. Getting SRS Light flashing intermittently and AIRBAG FAULT error message on dash. Can this be fixed by resetting codes or should I be looking for something else?
Thanks.
Old Jan 27, 2010 | 12:25 AM
zoobidubi123's Avatar
3rd Gear
Hi,
Here some information about the Airbag.
Airbag-SRS needs a check after 10 years.As I recently reported, Volvo have increased the recommended airbag life from 10 years (as indicated on the sticker) to 15 years. They do advise that a check of the system should be performed by a Volvo dealer after 10 years. I had the said check performed today. It consists of plugging the SRS system into the computer and check for any error messages. The cost was one hour labor ($63 minus 10% in my case in NJ). Not surprisingly, the check revealed that everything was OK. I guess that I would rather spend the money than discover a malfunction in the event of an accident.
Old Jan 27, 2010 | 11:12 AM
handsome rob's Avatar
Mine will do that if I go through a car wash with an unside wash. I think it is a sensor somewhere that gets wet and then sets off the message. It goes away right away once the water is off. I have never had it do it while driving though while it is raining or snowing.
I agree with zoobidubi, they do need to be checked every ten years or so, I just have never done it.
Old Jan 27, 2010 | 11:15 AM
hilltoppersx's Avatar
could be multiple things. mine is on as well and it could be a seatbelt sensor or the pre-tensioner or an airbag module...
Old Jan 27, 2010 | 11:16 AM
faversham's Avatar
Default You MAY BE RIGHT!
Today, error message + SRS light gone. Day before fault was pouring. I wonder? Thanks.
Old Jan 28, 2010 | 06:26 AM
Rovin4life's Avatar
seat harness gets a little stetched.
Old Jan 28, 2010 | 04:59 PM
wilson96rr's Avatar
It is a 1996. There isn't a harness under the seat is there? I thought the seat harness started with the 1998 model.
mike031
14
Nov 2, 2018 10:41 PM
Pbpuckett
LR2
Feb 5, 2014 09:07 PM
Disco2001
Sep 4, 2011 12:13 AM
NATEDOGG
Oct 14, 2009 03:27 PM
