Intermittent Wipers
Old Jan 9, 2012 | 10:30 AM
PJH's Avatar
PJH
5th Gear
Default Intermittent Wipers
Hello, I am new to the forum, looking for some assistance with Intermittent Wiper problem. Any help is greatly appreciated - have searched forums with no luck.
I have a 2007 LR3 SE w/57K miles. Vehicle is equppped with rain sensative wipers.
I have never had a problem until two weeks ago. Now wipers do not work at all in intermittent mode. Fornt and rear wiper can be activated manually by pushing switch down for single wipe or setting to high mode. When you pull the switch down to activate a single swipe, the wipers stop as soon as you let go of the switch - they do not return home to the bottom of the windshield. Same thing happens if you shut off high mode, the wipers stop wherever they are on the windshield.
If anyone has had this problem or has any advice, suggestions would be very much appreciated.
Thanks!
Old Jan 9, 2012 | 08:09 PM
Rovin4life's Avatar
if the wipers stop wherever they are then the motor is bad itself. seen it a few times.
the park switch has failed.
Old Jan 10, 2012 | 06:19 PM
PJH's Avatar
PJH
5th Gear
Thanks. Very big help, the closest LR dealer is 90 miles away. I will get one on order and report back.
Thanks again
wblake
Oct 24, 2007 08:32 PM
DiscoGravy
Jun 26, 2006 03:26 PM
jh2
Nov 13, 2005 06:57 PM
georgery
Freelander
Nov 7, 2005 02:26 PM
brianwi11iams
Jul 20, 2005 02:36 PM
