What does this mean? Further emission issues....
Old Jul 3, 2019 | 07:22 PM
Philip Chan's Avatar
Default What does this mean? Further emission issues....
So my cat fault is no longer showing up! Yeah! BUT
I now have a P0170-00 (E8) Bank 1 Fault showing up...
Does this mean its running lean? or what does it mean?
I used my GAP tool to look at the o2 sensors just to compare.
Bank 1 - sensor 1 is -133ma / B2 Sen1 is -23ma
Bank 1 - sensor 2 is 0V / B2/Sen2 is .7v
Is that normal?
Old Jul 5, 2019 | 11:20 AM
abran's Avatar
You probably have an air leak post MAF. Check all connections. If you have a smoke tester, you cold use that to find the leak. Keep in mind the EGR valves always leak.
Good luck
davecason
Jan 13, 2014 12:37 PM
RealRitzcracker
Aug 29, 2012 09:12 PM
cardinal77
Jun 6, 2009 01:14 AM
salve7
Mar 19, 2009 01:03 PM
