Front bushings?
Old Jan 6, 2012 | 06:29 AM
Kevin Kelly's Avatar
Default Front bushings?
I need to replace the bushings on the front end of my '06. You can hear them rattle something awful. Is this something that has to be done by a dealer? If not, anyone know a good place in BR to take it to?
Thanks,
kevin
Old Jan 6, 2012 | 10:05 AM
unseenone's Avatar
It can be done yourself depending on availability of tools, a workspace and your technical skills. In order to suggest a shop to take it too, you would need to mention where you are.
Old Jan 6, 2012 | 02:13 PM
Yes, that would have been helpful, wouldn't it? I thought i had mentioned Baton Rouge in the title, which is why i just said "BR" in the post. Clearly, i wasn't paying any attention. I'm in Baton Rouge, Louisiana.
Thanks,
kevin
Old Jan 6, 2012 | 02:16 PM
Adigorn's Avatar
If you have lower wishbone on mind be prepared that sometimes bolts are so stuck inside the bush that has to be cut off
so removing the wishbone from the car might be the most difficult pat of the job
Old Jan 7, 2012 | 11:08 AM
Rovin4life's Avatar
if you want to try and do it yourself or pay someone first mark the bolts on both sides where they sit with white paint and then loosen the nuts and make sure they spin freely. in your area its possible they can. if not you have to buy a sawzall to cut them out. that is the only way.
Old Jan 7, 2012 | 07:46 PM
Not going to try this myself. Don't want to screw it up worse and then need a tow on top of the repair.
Old Jan 8, 2012 | 09:55 AM
unseenone's Avatar
You can find step by step instructions on disco3.
Here are a couple of suggestions, seeing as nobody from the area has responded. I am not endorsing any of these folks, I don't have any direct experience. I suggest you start by letting your fingers do the walking, and call around. If you like the attitude on the phone dig deeper, if not, move on. A good independent shop will be willing to try anything .
It helps if you have done your research, ie: check out the how to on the disco site, figure out which parts you need, order them in, or the shop will end up going to the dealer and overpaying. Plan it out, so they shop is prepared.
These guys are a lucky8 affiliated shop.
The Shop
727 West Peachtree Street
Norcross, GA 30071
(678) 352-4900
Edwards Automotive, in business since 1913
Edwards Automotive Service - Seattle, WA - Home - Auto Service & Repair - Seattle, WA - Edwards Automotive Service
Local Dealer
Baton Rouge Jaguar, Land Rover Dealership | New Orleans, Lafayette, Denham Springs, Shenandoah | Paretti Baton Rouge | Louisiana
DavC
Jun 20, 2015 02:37 PM
Andy2Rover
Sep 24, 2012 11:12 AM
troverman
May 7, 2012 05:21 PM
fastrx7man
Jan 28, 2012 12:49 PM
ajh
Nov 3, 2006 07:27 PM
