Replacing Control Arms
Old Nov 15, 2011 | 04:49 PM
01d2Jeff's Avatar
Default Replacing Control Arms
Any tricks to removing/replacing the lower control arms on the LR3 before I tackle the project this weekend?
Old Nov 15, 2011 | 08:07 PM
threalassmikeg's Avatar
When removing/installing spindles, cover the lower ball joints with a rag or 2 to prevent the lower ball joint from cutting the cv boot.
Tie the front driveshafts up so they don't hang (the inner cv joints like to pop apart)
Make sure you have a sawsall and lots of blades to cut out frozen camber/caster bolts.
Don't damage your catalytic converters with your hammer
Don't install the control arms upside down and backwards. You'll hate youself.
Install NEW camber/caster bolts and hardware
Be careful when reassembling and tightening the camber/caster bolts, and when trying
to adjust them. The locating tabs on the chassis are fragile and damage easily.
Old Nov 15, 2011 | 09:14 PM
Rovin4life's Avatar
mark the camber bolts and reinstall them as best as possible.
Drive the vehicle at least ten miles and the perform the alignment.
You will need an outside shop, the trick to doing the alignment is to let the vehicle run with the door open after its in its regular position. then you can align the vehicle correctly.
Old Nov 21, 2011 | 05:58 AM
How'd you make out d2jeff?
Did you vibriate any teeth loose??
Drillbit
Apr 4, 2014 02:10 PM
Northwind
Dec 11, 2012 10:48 PM
iownme
Mar 4, 2011 09:00 AM
dutter44
Feb 12, 2009 08:24 PM
millejdq
Dec 6, 2007 12:23 PM
