Rock Armor Rod problem
#21
I hope you can see the pictures on the following link. I did some pictures.
I think the rods didn't make their work on the front side...
HERE ARE THE PICTURES:
https://www.dropbox.com/sh/w9a6c5prx...EysqFLOra?dl=0
#22
Rod height pics
Hey Boneless here's how my truck looks with the rods. I haven't had a chance to take a pic of my rods side by side yet, had to change out 4 belts in the wife's volvo 240. Many rusted bolts, 4 hours long and tons of swearing.
Your truck should look like its in offroad height with the rods. Take a look at the pics of mine.
boneless (12-23-2014)
#23
#24
#25
Thanks!
But I don't understand, why not rise the front up These are simple parts, "like a screw".. Why not work? Maybe the sensor broken? Is it possible? But when I switch Off-Road Height both of sides rises up. And the front is rises fast like the rear to off road height. But Normal Height not okay, what you saw in the pictures
#26
Height problem solved, but the Suspension warning light still make problem when driving fast on concrete.
I remove the Rock Armor Rods, and set the originals back. Then me and the mechanic set the height on the Computer(like the GAP IIDTOOL) with a Bosch Diagnostic System and we can save the settings. So the car looks like off road mode and doesn't need rods.
But, when I driving on concrete and the car's sensors perceive the flat ground, the car drop the suspension fault light on the dashboard and drop the car to the bump stops or Access mode? (lowest mode)
We can read some issue codes with the Bosch Diagnostic and it shows the problem is in the Rear right wheel...
I have no idea what could be the problem.
#28
#29
I haven't got a NAV system, but we read the codes: u0421 c1a751 c1a0762 c1a0054
The mechanic sad, the compressor can't hold the height when driving, and overheat.(But that just when driving fast on concrete). He suggests try to clean the filter in the compressor or change it for an Arnott, because it has bigger performance, but it so expensive.
Blakesrover
02-20-2013 10:31 PM
