Very confused need help !!!!!!
Old Aug 20, 2009 | 03:18 PM
ALEXAN's Avatar
Default Very confused need help !!!!!!
Hi every one my name is Alexan and I am currently a 2004 Disco II SE7 owner. My Disco is in very clean and great condition. My Disco just made it to 85k miles (all inner city driving) and I want to make some changes to it. I am a little concerned about some of the parts that I have found. I am concerned because I don’t know what parts are quality or good for my car. I just want to give my car one major heavy duty tune up and make over now that I have the chance to so I don’t run into any problems or have to make any changes to it for years to come.
The changes I want to make are as follows below.
New Tires
Heavy duty rotors
Heavy duty brake pads
Heavy duty calipers
Heavy duty shock absorbers and springs
Heavy duty tune up parts
I did a little research and came up with the following parts
Tires: Good Year Fortera Triple Tread Size 255/55R18
Rotors: Brembo Sport Rotors Drilled & Slotted (www.brakeworld.com)
Brake Pads: Disc Italia Hyper Ceramic Brake Pads (www.brakeworld.com)
Calipers: A1 Cardone Brake Calipers (www.autopartswarehouse.com)
Shosck absorbers & springs: Discovery heavy duty Bilstein shock absorbers & land rover springs kit
(http://www.roversnorth.com/store/p-6...eavy-duty.aspx)
I couldn’t find a tune up kit
Please if some one is willing to advise me on my situation I would really appreciate it feel free to email me at alexanputrus@yahoo.com or even call 773-640-2339
Old Aug 20, 2009 | 03:27 PM
hilltoppersx's Avatar
slow down.....
what about the drive shaft? have you had that rebuilt? what about the head gaskets? are you leaking any fluids? coolant/oil or both? check out Disco Mikes 60K service sticky under the disco section. You might want to throw some magnecor 8mm wires and bosch +4 platinum plugs in there as well... i would just do the maintenance sticky then work on from there.
Old Aug 20, 2009 | 03:31 PM
ALEXAN's Avatar
none of the problems you mentioned thanks for the tips keep them coming
Old Aug 20, 2009 | 03:34 PM
did you have the drive shaft rebuilt? or no? its not a problem until it blows apart and destroys the transmission and takes out the transfer case with it...
Old Aug 20, 2009 | 03:37 PM
ALEXAN's Avatar
never rebuilt
Old Aug 20, 2009 | 03:51 PM
well factor that into your list of things. if you want to rebuild it will cost you under $200. Or you can buy a new one from Tom Woods for around $320. The rear drive shaft also should be replaced.
Old Aug 20, 2009 | 04:16 PM
ALEXAN's Avatar
If you get a chance can you tell me the exact name of both parts you suggested i should change as it is listed in Tom Woods website. Was just on his website little confused on which ones they are thanks
Old Aug 20, 2009 | 05:11 PM
here is a thread on the Tom Woods DS
https://landroverforums.com/forum/sh...ht=drive+shaft
here is a thread on the drive shaft in general
here is the thread on the 60k service that everyone should do.
https://landroverforums.com/forum/sh...ad.php?t=19776
Old Aug 23, 2009 | 01:13 AM
ALEXAN's Avatar
Thanks for all the info guys
Old Aug 23, 2009 | 10:00 AM
no problem
foamwizards
Sep 16, 2011 05:28 AM
MikeThomas
May 10, 2011 10:21 AM
crownaviation
Feb 22, 2008 10:01 AM
pureanal
Jul 11, 2006 09:29 PM
