Newbie Rover Owner
Old Aug 7, 2011 | 01:46 PM
rovernoy's Avatar
Default Newbie Rover Owner
Hello fellow Land Rover owners i just bought a 2001 Land Rover Discovery 2 with about 140k. Figure not to bad for my first LR.
Old Aug 7, 2011 | 02:14 PM
photocrimes's Avatar
Bright side is at 140k anything that could go wrong most likely has ;-)
If you like turning a wrench you'll love this truck!
Old Aug 7, 2011 | 09:25 PM
Yep, download that RAVE tech manual set, check out the technical section of the forum for a big to-do list, get a new set of coveralls, a pair of ramps, and map out locations of nearby auto parts stores, Harbor Freight, salvage yards, and internet listings for our favorite dismantlers and Rover based parts shops. You'll want to spend some time under the Rover checking things out. Don't worry about the small oil leaks, it is an undocumented feature for continuous automatic anti-rust application.
Old Aug 8, 2011 | 09:02 AM
rovernoy's Avatar
What have i got myself into? lol Well thank you for the info. I am a regular at the salvage yard and was actually going to ask what should i do next and what to look out for.
Old Aug 8, 2011 | 10:39 AM
The maintenance list in the technical section of the forum is a good place to start. Alternators seem to be a favorite.
Old Aug 8, 2011 | 11:59 AM
If you drive a lot like I do, get a cps to throw in your glove box just in case. They are only $70 and its cheap insurance. This is the one part on your engine that has a habit of leaving you stranded with no warning. Better to have it on hand than waiting days for some garage to find one. Just my 2 cents.
Old Aug 15, 2011 | 11:19 PM
rovernoy's Avatar
Dont plan on driving the truck everyday. More like a weekend kind of thing. Thanks for all the feedback
Old Aug 24, 2011 | 07:14 AM
rovernoy's Avatar
Is there an oil and filter that i should use that would be more suited for this type of vehicle? I'm doing the first oil change this weekend. I live in Las Vegas and it will most likely be 100+ daily till maybe early sep then it should go to high 80's mid 90's till about Oct. Also because the truck was sitting for a few months should i replace all the fluids?
Run33
May 11, 2015 09:43 PM
GandAautoLLC
Aug 18, 2011 06:29 AM
BigG-UK
Feb 15, 2009 05:55 PM
robertl
Aug 20, 2005 11:07 AM
gwelland
Feb 9, 2005 04:16 AM
