Go Back   Land Rover Forums - Land Rover Enthusiast Forum > General Land Rover Forums > New Member Introduction
Register Forgot Password?
Old 01-24-2012, 05:22 PM
thebloody's Avatar
Senior Member
Smile New Disco II
Hi all, I would just like to post and say "hey".
I just bought a 2004 Disco with 83k on and was just wondering if there are is preventative maintenance I should do. I already plan to change the oil, bleed the brakes and change the thermostat, but is there anything else I should look into?
A bit about myself:
This is my first Landie but my dad has two Series II (109 and 88) and we are converting the 109 to a 300Tdi. The 109 has been in the family for about 25+ years now. When I was very young my dad bought it from a scrap yard and I helped him rebuild it so I do have some mechanical knowledge (I am by no means an expert though, that would be my dad). We also had a 300Tdi D90 but alas had to say goodbye to it when we moved to the US.
Old 01-24-2012, 07:27 PM
Senior Member
Welcome. The whole factory manual set, called the RAVE, is a free download below. Also see Major Service. for service items to catch up, and check out our tech area, in particular a write up on how to refit the front drive shaft with grease fittings. The stock shaft will chirp, split, and spear a hole in the transmission, usually well over $5,000 repair bill. If changing thermostat consider flush of radiator and change to green coolant, especially if fitted with orange Dexcool. This time of year you can run 15W40 Rotella or if really cold, 5W40 Rotella (by Shell). It is a diesel rated oil that has a lot of cleaning chemicals well suited for the older design engines. 10W30 is too light. You should also look at transmission flush, filter, and new fluid; and diffs and transfer case. Lots of things on the bottom side of a Disco. On the serious PM side, consider a manual oil pressure test, so you will know if your oil pump is up to spec.
__________________
Old 01-24-2012, 07:52 PM
thebloody's Avatar
Senior Member
Awesome, thanks for the info Savannah I appreciate it. I will definitely flush everything and take a look at the Major Service section and run through the list.
__________________
2004 Disco II "Dagga Boy" 84k miles
Mods: Coild Spring conversion/2 inch lift, Rovertym front and rear bumpers, steel rims and 32's Wrangler AT tires, RN Hood blackout, Prop shaft rebuilt, Ultra Gauge installed, Mantec Snorkel Installed.
Northeast Land Rover Club
www.nelrc.com
RAVE tech manuals available at http://www.landroverresource.com/
Dagga Boy: The Zulu term for a solatary large old male Cape Buffalo that spends all day wallowing in the mud.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
