ABS DSC and Air Suspension Inactive? 04 RRHSE
Old 09-01-2008, 06:18 PM
Brad S1's Avatar
Default ABS DSC and Air Suspension Inactive? 04 RRHSE
I've had this truck for a few days, no real issues... I had the RR in access mode EG suspension dropped, I pulled out of a parking lot onto the highway in this mode, as soon as I got up to speed it started to raise itself up, then "DSC Inactive" ABS light, and "Air Suspension Inactive," Pops up.
It auto leveled the height, but the suspension went into the hold mode which locked me out from selecting different ride heights.
I went outside to check some fuses, but it's fine now... Raises up max, lowers max etc... No warning lights or messages?
What's that all about? Should I not be driving around in access mode? I figured the computer would figure it out and just raise it up, which it tried to do before all these error messages came up.
Old 09-02-2008, 11:03 PM
roverguy7's Avatar
Default RE: ABS DSC and Air Suspension Inactive? 04 RRHSE
it will raise itself... the problem was that when it was raising itself it saw something wrong, hence the warning lights, your eas went into fault mode... could be a lot of different reasons why it did, you need to get the codes checked. they had a big problem with the compressors, the parameters are set too high and itll set a fault for the pressure not incresing because the compressor gets too hot, usually fixed with a software update, sometimes the compressor craps out... get it checked
griff black
06-23-2016 05:59 PM
NhudeST
03-14-2011 01:50 PM
griff black
05-01-2010 07:33 AM
Nato
01-19-2010 12:40 AM
devildog
12-24-2008 06:02 AM
Quick Reply: ABS DSC and Air Suspension Inactive? 04 RRHSE
