Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > Range Rover
Register Forgot Password?
Old 07-15-2011, 10:10 PM
Senior Member
Default Positive ground system or Negative ground system on the P38 02 RR 4.6?
"Determine what type of ground system the vehicle is operating on. A positive ground system will have a positive post for the battery connected directly to the vehicle chassis, while a negative ground system will have the negative post connected to the chassis."
Better to ask then to guess and be dead wrong. Can someone set me straight on this issue?
__________________
RROJ
Range Rover 4.6 HSE 2002
86,000 Enjoyable Miles!
Java Black
Old 07-15-2011, 11:53 PM
Member
NEGATIVE GROUND.
I know the old MG's have/had a positive ground but England finally lined up with the rest of the world on this.
The easiest way to see for yourself is to look at the battery and the battery cables. Follow the black wire from the battery to where it is bolted to the chassis which I think is behind the battery box.
__________________
Don't spill the beer!
ol' Blue, 2000 RR HSE 116K miles
Old 07-24-2011, 05:38 AM
Junior Member
AViciousBiscuit AviciousBiscuit
i never knew that anywhere did any of that ass backwards... i guess you learn something new everyday
good to know
Old 07-24-2011, 07:59 AM
antichrist's Avatar
Senior Member
There really wasn't a standard until the '60's, though most US manufacturers standardized on negative ground in the 50's. Other manufacturers in the rest of the world, most notably the British, kept positive ground until the mid-60's.
You can't always rely on the color of the cable, particularly if someone has replaced the cable.
All batteries are marked with a '+' and '-' next to the respective posts. On top post batteries the positive post is larger than the negative post.
For some reason side post batteries have the same size terminals so you have to rely on the markings.
If the car is newer than a '75 it's definitely a negative ground.
__________________
Tom Rowe
Four wheel drive allows you to get stuck
in places even more inaccessible.
62 88 reg
67 NADA x2
74 Air Portable - The Antichrist (tag 6A666)
95 D1 - R380
95 D90 - R380
97 D1 - ZF
Tags
battery, connected, determine, ground, grounded, negative, positive, post, range, round, rover, system, systems, sytems, vehicles
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
