Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > Range Rover
Register Forgot Password?
Old 07-25-2011, 12:52 AM
Member
Default Rover won't shift into low range gears
When I shift my 2000 Rover into the low range gears I do not get an indicator in the message center. The shifter moves smoothly from the high side to the low side, and the shifter moves normally through all the low range. It's obvious the truck has not shifted into the low range when driving. I'd like to trouble shoot and repair this problem myself if it doesn't get too big; is there a trouble shooting flow chart somewhere for this problem? If not what would be the common causes I should look for with this problem? I've looked through the electrical and mechanical sections of the manual but no joy. Any hint is appreciated. Thanks.
P.S. I also noted that the sport and manual switches don't appear to be functioning either. The shift cluster does not light up at night as well.
__________________
Don't spill the beer!
ol' Blue, 2000 RR HSE 116K miles
Old 07-25-2011, 01:22 AM
Junior Member
AViciousBiscuit AviciousBiscuit
make sure your truck is in neutral first, your tcase ecu could be the culprit, check this out for some additional help
Range Rover P38/4.0/4.6 Common Problems and Fixes
most range rover problems can be fixed through that site.
it could also be the switch the tells the computer you want low range
__________________
95 P38 107K miles
latest tech write up
http://www.rangerovers.net/forum/vie...hp?f=3&t=47043
Old 07-25-2011, 10:33 PM
Member
Thanks. Yes, I stopped and had it in neutral before going from Hi into Lo range. I also noticed for the first time that when I shift through 1-D, the message console (backlite burned out so hard to see) shows the gears stop at 2 and does not go into first gear.
I'm going to check connectors and such first.
__________________
Old 07-26-2011, 11:59 AM
Junior Member
i have the same problem and its due to play in the shift linkage. ill try playing with it and see if i can come up with a solution
__________________
95 P38 107K miles
Tags
2000, change, gears, land, landrover, low, lowrange, p38, range, rover, shift, tech, tips, vehicle, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
