Rover won't shift into low range gears
Old Jul 25, 2011 | 12:52 AM
Ringo's Avatar
Default Rover won't shift into low range gears
When I shift my 2000 Rover into the low range gears I do not get an indicator in the message center. The shifter moves smoothly from the high side to the low side, and the shifter moves normally through all the low range. It's obvious the truck has not shifted into the low range when driving. I'd like to trouble shoot and repair this problem myself if it doesn't get too big; is there a trouble shooting flow chart somewhere for this problem? If not what would be the common causes I should look for with this problem? I've looked through the electrical and mechanical sections of the manual but no joy. Any hint is appreciated. Thanks.
P.S. I also noted that the sport and manual switches don't appear to be functioning either. The shift cluster does not light up at night as well.
Old Jul 25, 2011 | 01:22 AM
DCNick's Avatar
6th Gear
make sure your truck is in neutral first, your tcase ecu could be the culprit, check this out for some additional help
Range Rover P38/4.0/4.6 Common Problems and Fixes
most range rover problems can be fixed through that site.
it could also be the switch the tells the computer you want low range
Old Jul 25, 2011 | 10:33 PM
Ringo's Avatar
Thanks. Yes, I stopped and had it in neutral before going from Hi into Lo range. I also noticed for the first time that when I shift through 1-D, the message console (backlite burned out so hard to see) shows the gears stop at 2 and does not go into first gear.
I'm going to check connectors and such first.
Old Jul 26, 2011 | 11:59 AM
DCNick's Avatar
6th Gear
i have the same problem and its due to play in the shift linkage. ill try playing with it and see if i can come up with a solution
gmad
May 9, 2015 11:25 AM
importdave
Sep 25, 2014 10:18 PM
NiteTrain
May 14, 2008 08:43 PM
discotx
Dec 22, 2007 10:08 AM
