Transmission fluid
You need dexron III ATF. I think my fluid is valvoline, conventional dexron III atf. I had a local rover shop do it. Sometimes the newer dexron IV atfs (that say you can use it for dexron III applications) will cause the transmission to make grinding/sucking noises. This happened to me after I just bought the rover and it scared me to death. You may also want to add some lucas transmission fix. Many of the guys on the disco forum including myself use the stuff and love it.
exhaust
spray some DEEP CREEP on the exhaust studs a few day and the a few hours before removing the exhaust manifold studs. On my 1993 I needed to drop the front Y pipe and remove the cross member -- a lot of pounding to get out that crossmember.
Get 2 new exhaust manifold gaskets and new exhaust nuts from a rover dealer to seal up the pipe.
LRScott
03-04-2009 08:39 AM
