Major Service.
Old May 20, 2010 | 03:36 PM
  #21
camgkh's Avatar
Disco mike can you please explain how to flush and change some of theses fluids?
in detail. i need help
Old May 26, 2010 | 12:18 AM
  #22
JavaDiscoII's Avatar
i just want to double check before I go buy an a$$ load of gear oil. Any reason why I should not buy mobil 1 synthetic 75-90 gear oil rated GL-5? It is the same price as red line, but easy to get and right now there are coupons to advance so I could save some
major coin.
Also, what lube do you guys use for greasing various components ( and what components, I see people say slip shafts? But that doesn't even come up on a search in rave)? Mobil makes a synthetic one, too but idk if that is over kill. Edit: besides the u joints, OBVIOUSLY! :-)
Old May 26, 2010 | 07:09 PM
  #23
fireman200141's Avatar
hay mike i own a 96 dec. land rovre, and it likes to hesatate some times when i am driving and wanst to get hot.i dont know what to do. any clues?
Old May 30, 2010 | 09:38 AM
  #24
rtonder's Avatar
Regarding the anti-freeze: Both my vehicles need a block heater to start in the winter. I believe its standard equipment on Canadian vehicles. The instructions for installation indicated lifting the front of the vehicle six to twelve inches when re-filling to reduce air locks. Seems to make a big difference and I've never noticed the same instructions in RAVE.
Old Jun 10, 2010 | 11:18 AM
  #25
jdhuegel1's Avatar
Originally Posted by 2001SE7
For Genuine Land Rover parts I order from landroverpartscenter.com
No offense - but there's not one thing on that site that is reasonably priced.
Y-Pipe and catalytic converters on landroverpartscenter.com = $2,413.00
Y-Pipe and catalytic converters on atlanticbritish.com = $549.95
I've found them cheaper than that though...
Not trying to be a d1ck. That's just one of the many things I compared prices with. They are not 'internet prices'... they're 'landrover prices'.
Old Jun 11, 2010 | 01:05 PM
  #26
2001SE7's Avatar
Hi jdhuegel1, I don't think you are anything bad. If you read my post I made it more than clear one should always do their homework to find the best deal. I check every vendor I can find before I make my decision. And the parts I did buy from them were the lowest price for the particular part(s) I could find at that time. You didn't quote my full post which is a trick a lot of politicians use to discredit there opponent when they can not compete with their own merits. You also used "The Land Rover Parts Center"'s MSRP price; not their discounted price. And of coarse a genuine Land Rover part (my post was perfectly clear said "GENUINE" PARTS which you also conveniently took out of context) will cost more than imitation made in Indonesia. If saving money is your first concern when it comes to your Rover that is your business. The remark you made about there not being anything on their site that is priced reasonably is a pretty broad statement. I try to keep my Rover as genuine as possible. I am not offended in the leased. BTW; sometimes their price is the lowest for a genuine Rover part; that's when I use them.
Old Aug 20, 2010 | 11:03 AM
  #27
Spencerfitch's Avatar
Just wanted to throw this out there If you want to save a little cash Bosch has a larger filter to. Its the BOSCH 3500 Half the price of the others and manufactured by purolator I believe.
Old Sep 4, 2010 | 12:37 PM
  #28
hebgbz's Avatar
Default p1590
hey disco mike, you've been a great help in the past w/my 03 disco took care of the misfire issues everything fine till i decided to detail the wifes car then p1590 popped up . i know it came on when i cleaned the rims w/cleaner. all i need to do is reset the amigos i tried using my obd and i think its a little more than just pressing erase. i know there's a way of resetting it but just dont know how , fill me in please thanks for all your help mike
Old Sep 4, 2010 | 03:08 PM
  #29
A 1590 code is on because your 3 Amigos is either on or has come and gone. If the 3 Amigos come and goes, you need to deal with the problem before they set a hard code and stay on cause it will cost you an easy $100 plus just to turn it off.
As for the 1590, it can't be cleared till you fix the brakes.
Shout if you want some help with this.
Old Sep 5, 2010 | 11:19 AM
  #30
afeomun2's Avatar
Hi Guys,first time here and boy you are talented, I need help:
2003 disco. trouble codes;P0340,P0441,P1300, can you suggest anything?
car runs ok but the service engine light came up (85000)
