Suspension sponsored by Arnott Inc. Talk about your suspension within.
Spring / Shock upgrade
Old Jul 29, 2007 | 04:33 PM
discotx's Avatar
Default Spring / Shock upgrade
I have a '99 disco that I would like to upgrade springs and shocks. A couple of questions though...
If I put heavy duty springs and shocks on it will that actually raise the car an inch? I have heard this.
If true, that inch shouldn't throw off the drive shaft angles or mess anything up will it?
Is it true that only certain shocks will work with my ACE.
I found an AT tire that is my stock 255/55-18 size..I am hoping to not have to do any body work..
Thanks in advance for the advice!!!
Old Jul 29, 2007 | 11:25 PM
llesra's Avatar
Default RE: Spring / Shock upgrade
if you put hd springs on, yes it will lift the truck
if you lift it that small amount, the driveshafts will be ok
no its not true
thats the same tire size as stock so there wont be any issues
Old Jul 30, 2007 | 07:28 AM
discotx's Avatar
Thanks!
The only reason for the ACE question was I did see shocks that in thedescription it said "will not work with ACE"
Is there a preferred brand by disco II owners? I see a lot of discussion about OME stuff...
Old Jul 31, 2007 | 09:41 AM
I have seen that statement on Bilstein shocks and don't understand why it should be an issue. I have a 2.5" lift and run OME H.D. shocks with my ACE and SLS with no problems.
Yes, you will get a 2" lift when going to new springs, but the end result will be less the 2"s after you consider how much your old factory springs have settled over the years.
Mike
Old Jul 31, 2007 | 08:54 PM
discotx's Avatar
Mike,
So in summary, getting just new heavy duty springs and shocks will raise the vehicle, but less than 2", and that will not mess up anything with my drive shaft agles or brake cable lengths etc.....?
I think that extra inch or so will make it possible for me to put on some 255/60-18...I think those are about aninch taller than my stock 18's....I know 16s are the way to go if I get serious about where I go off road....but for now I think the 18's will have to do...but the 255/60-18 give me little taller side wall.....
Old Aug 4, 2007 | 08:44 AM
You will be just fine going up to 2"s and have no problems with the drive lines or your ACE.
I have a 99 D2 with ACE and SLS running a 3" lift with no problems.
Let me know if you haven't bought your lift yet, I have a couple of good connections for outstanding prices on Old Man Emu suspensions.
Mike
Old Apr 16, 2008 | 05:23 PM
rwarren92's Avatar
so a disco1 can run a 2" with out having to get extendedbrake lines
Old Apr 17, 2008 | 11:41 AM
I am currently running a 3 inch lift with no drive line changes, only brake lines and Old Man Emu coils and shocks. There are different coils to pick from, so check with me and I'll be glad to help you with that.
Have you already replace the 2 u-joints on your front drive shaft, if not, that will need to be done, with or with out the lift.
Chrisinhouston
Jun 13, 2009 07:27 AM
llPANCHOll
Feb 9, 2009 01:49 PM
avking
Jan 23, 2009 08:27 PM
FordCrusherGT
Jan 27, 2007 08:09 PM
