Tires What skins are you rollin' around on? Discuss wrapping your rims in here.
military spec. tires for land rovers
Old Feb 4, 2008 | 11:33 PM
raid13's Avatar
Default military spec. tires for land rovers
hi, looking were to buy five
michelin XZL's in size 7.50 R16 and
how much lift do i need to fit them under a discovery II?
thanks
Old Feb 5, 2008 | 03:59 PM
Default RE: military spec. tires for land rovers
Any 2"OME lift or RTE 2" should be more then enough.
Old Mar 18, 2008 | 06:59 AM
antichrist's Avatar
Yeah, 2" is plenty. I run Goodyear G90's sometimes in 7.50x16. Needed a bit of rear fender trimming on my D1, probably not on a DII.
Old Mar 18, 2008 | 09:39 AM
Why would you want to run them on your Disco, they will beat you to death and there certainly are many other sizes that will give you more traction off road?
Old Mar 18, 2008 | 11:03 AM
antichrist's Avatar
Actually the G90's are one of the best off-road I've ever used. Sadly they suck for longevity if you run them on tarmac. But I typically run load range D or E tires. My next set will probably be another set of Cooper STT's.
Old Jan 24, 2010 | 01:56 PM
jafir's Avatar
Do the 7.50X16 tires fit ok on the stock Disco I 7 inch rims? I've got a set of stock steel rims that I was thinking using for some 7.50X16.
Old Jan 26, 2010 | 09:18 AM
Be careful when buying any of the old 750/16 military tires, many are way to hold to be safe, check the manufacture date to be sure, if they are over 5 years old, beware.
Old Jan 27, 2010 | 06:33 AM
jafir's Avatar
Yeah, I understand that, I watched that video that someone posted. The tires I'm looking at aren't military, they are probably considered farm truck tires or something. They are Mastercraft/Cooper Courser Traction LT. They are tubeless bias ply, and fairly cheap. I found a spec sheet somewhere online and it said that 7 inch was the maximum rim width, but I want to make sure that that not just a little too wide. I'd hate to be getting lots of flats because the side wall it rubbing on the ground. ;-)
jonslide
Jun 9, 2014 06:19 AM
TRIARII
Jan 13, 2014 10:39 AM
TRIARII
Sep 2, 2013 07:52 PM
wastedincome
Oct 24, 2012 03:10 PM
y2motoskier
Apr 28, 2012 02:31 PM
