The wheels are 20 x9.5" with an offset of 32mm The tires are 33 x 12.5 x 20.
For all of you wanting to know: Yes, unfortunately they rub on the inner fender liner at full lock. I'm going to work with a heat gun tomorrow to get the extra room I need. I also suspect that the inner cloth type sound barrier will have to be manipulated too.
Factory wheels offset is +41.5 across the range of sizes and styles: 18, 19, 20, 22", alloy or steel.
here’s a bug of information. I have the 1.5” Johnson lift rods and am running a 275/60R20 BFG KO2’s. They fit fine but with very little room to spare. I tried using 25mm spacers and the front tires rubbed front and back at full lock. If you’re running mud flaps the tires catch. The inside lip of the flaps. Sufficient to say that 41.5-25= 16.5mm offset. Redbournes are 25mm and I wonder if that is still too aggressive. For now the redbournes are out of stock everywhere. Tempted to buy just one to try it on a front wheel before ordering all 5.
