“Advised tire pressure” question
Old Dec 18, 2025 | 07:55 PM
KamboMD's Avatar
Default “Advised tire pressure” question
Hey guys,
I'm in Northern California, its not crazy cold, maybe in the 40's at lowest, and after owning the car for 4 years, and being in even colder temps, I am for the first time seeing the advised pressure changing and telling me I have low air when they are at like 32psi. It's suggesting 42psi up front, and then 49 in the back. If I fill them up to the suggested pressure, the monitor still reads tire pressure warning and then the advised PSI drops back down to like 32'ish with no weather temps change.
Are my sensors just bad in the front? nothing occurs in the rear. I assume the advised PSI changes depending on temps, but I've been in below 0 temps and never have had this occur.
Old Dec 19, 2025 | 12:55 AM
GavinC's Avatar
Originally Posted by KamboMD
Hey guys,
Change your load setting to light load and then fill to a little more than that. No more errors and you can run at a more comfy psi.
Old Dec 19, 2025 | 11:27 AM
KamboMD's Avatar
great thank you I will try that!
Old Dec 19, 2025 | 12:59 PM
KamboMD's Avatar
thank you, this worked!
Old Dec 20, 2025 | 06:09 AM
Scotty2Thumbs's Avatar
How does one change the setting? Does it require a GAP tool?
Old Dec 20, 2025 | 07:18 AM
GavinC's Avatar
You use the buttons on the left side of the steering wheel.
Old Dec 21, 2025 | 03:46 PM
queezy's Avatar
Is it possible to change the “advised” tire pressure for each load setting? “Normal load” is well beyond my slightly oversized tires’ max pressure. I see how to change the “TPMS load setting” to either “normal” or “light”, but is it possible to set the advised values more appropriately for my tires? Thank you.
Old Dec 22, 2025 | 08:22 AM
CincyRovers's Avatar
It is not. Your only choices are normal and light.
Old Dec 23, 2025 | 01:42 PM
Sir Lands-a-lot's Avatar
Can the GAP tool adjust the Normal or Light default values?
Ehloo
Aug 11, 2024 04:59 PM
TRIARII
Sep 18, 2014 04:25 PM
0304Disco
Dec 6, 2012 01:44 PM
cpn LR
Jun 8, 2010 08:46 PM
