18” LR white alloys style 5093
Old Apr 29, 2024 | 10:08 PM
wlindsey@gmail.com's Avatar
Default 18” LR white alloys style 5093
Anyone know if these will work with the p400 and the caliper conversion?
Old Apr 29, 2024 | 10:48 PM
NoGaBiker's Avatar
Yep. I did it two years ago. The rear caliper conversion (using LR4 calipers, I think it is) isn’t enough for the OEM steelies; I still had to grind a tiny bit off a couple of high-spots, and I need to use 25mm or 30mm spacers for clearance on the rear, and I have to use external wheel weights (that clamp to the rim). But it works perfectly with those exceptions.
You can see the two wheel weights (blackened by me with a Sharpie) clamped to the rim at 7:00.
wlindsey@gmail.com
Apr 23, 2024 11:28 AM
willb
Oct 29, 2021 05:28 AM
philca
Jul 31, 2021 01:05 AM
GeoA(Atl)07SC
Jun 2, 2010 08:35 PM
