2020 check engine light
Old Jul 10, 2023 | 08:27 PM
Needledown's Avatar
Default 2020 check engine light
So I have a 2020 defender 110 with 52k miles.
every now and then it looses power press the gas and it slowly works it’s way to speed if I pull over turn the car off and restart it boom it’s back to normal strong take off. Then after that journey is over on the next restart it goes back to sluggish mode. Sometimes sluggish mode lasts for two trips and the check engine light comes on for 24 hours. Then goes off. The app says emissions problem.
it went in for service to fix the uneven HVAC
and I told them about this. They fixed HVAC but the road test was fine and no check engine light.
I feel like it’s the turbo working or not working ?
anyone else this issue or ideas?
aa
Old Jul 10, 2023 | 10:33 PM
nashvegas's Avatar
QQ -- Guessing you are in US/Canada -- if so, P300 or P400 motor?
Best first step if you aren't in the "drop it off at the dealer or indy" phase would be to get a good code reader (I use Gap IIDTool) and read the stored codes. That would be a start.
It quite literally could be anything from a loose wiring connector anywhere to an actual emissions issue to a fuel issue (or more..), so it's a bit hard to diagnose from afar. Unfortunately these are so new we haven't yet gotten the collective knowledge here to help diagnose, unless others have more technical knowledge than I do !
Old Jul 11, 2023 | 07:04 AM
Needledown's Avatar
I have the 4 cylinder turbo model.
are there any steps I can do myself?
like clean throttle valve?
check connections. And yea US area
my dealer is close but the dealer has no tools you drop off then they drive the car to the location where it gets fixed. They never have loaners so it’s always a mess
thanks for suggestions
Old Jul 11, 2023 | 08:21 PM
TeddyG's Avatar
cheap OBD dongle can also read codes. Won't as detailed as GAP or OEM but still something.
Old May 24, 2024 | 12:03 PM
Can_Glu's Avatar
To the OP, It has been some time. Just curious what you have found.
Thanks in advance for your update, which will benefit all those who are interested to hear from you,
Old May 25, 2024 | 08:06 PM
zac431's Avatar
I can't speak for the OP, but this sounds similar to an issue I had with my p300. Engine would stumble under load, such as going uphill, and it seemed like a boost cut. Sometimes the CEL would flash and it would go into limp mode. No message or CEL while in limp mode, but i couldn't get to 70mph on the interstate. My code reader wasn't showing anything. For me the solution was to replace the PCV valve. I also did the spark plugs while i was in tere.
Old May 26, 2024 | 02:39 PM
lightning's Avatar
His last post was on 19/1/24 and it still wasn't fixed
Old May 28, 2024 | 05:48 PM
is21447's Avatar
This exact thing happened to me and it was a couple of faulty fuel injectors. The dealership repaired them under warranty.
Easy3
Dec 5, 2025 03:50 PM
jemzimbo
Apr 17, 2023 04:43 AM
tkiel
Sep 13, 2022 02:57 PM
joelr5
Jun 7, 2021 11:23 AM
NCdiscoII
Nov 16, 2006 12:12 PM
