2022 Defender orders taking place now
#1561
#1563
The Bronco Raptor timing is impeccable for you, provided they can actually supply demand.
#1564
It was interesting today, since my boat docks tomorrow we are getting down to brass tacks. My Sales rep emailed me to let me know all the accessories I ordered are available and in a box for me. Now he knows I work on my own aircraft (I am licensed) and may well feel a bit ticked to overpay to have things like the mudflaps installed. My how perceptive he was. The mudflaps are only a few hundred dollars, however the want 3 hours of labor at $220 to install them! Honestly, I find that slightly unpalatable. Especially since on Friday I swapped out my Seaplane prop to the Landplane prop. This involves uncowling, taking off the nose bowl un-safetying the nuts removing the 85 lb propeller, changing the alternator belt (you do that each time you remove the prop, since its cost is trivial compared to having to do all that to replace it for wear). Which involves also removing the flywheel behind the prop. Putting the other back on safetying it running and rigging the prop RPM for the new prop and recowling. Making a logbook entry. I did that in 2.5 hours. So I have to assume that these mudflaps are a really complicated piece of kit, involving structural changes and re-programming the computer to take them into account. That and $220 an hour. Well that explains the really good coffee and pastries in the customer lounge.
So, needless to say, my accessory bits will be in boxes in the cargo area when I pick up the truck. Apparently, all the other stuff, rack, arches, skids, Eagle Beak inlays and such where put on at the factory.
So my lads, knowing I am anticipating the arrival or the someday Defender got me this. It arrived on schedule. Wrong color, but cute nonetheless.
The following 2 users liked this post by Dogpilot:
bobbyz95 (01-24-2022),
TrioLRowner (01-25-2022)
#1565
I actually cannot stand the Bronco. I'm not even sure what I'll look at, maybe a Tahoe RST. Really depends what the dealer says tomorrow. I'm not pressed to do something, but would like to sell my current while the market is good. But if I have to wait a year for a Defender, i'll want something else by the time I take delivery.
#1566
#1567
Well thank you for sharing that! My god, I will have to use a drill and a file! I'll have to root around to see if have those. Yes, it is an involved process for just mud flaps, considering on pretty much all other Defenders and Series it was something like three bolts a side. As you said, they over-complicated it. You want complicated, here is my turbine converted 206, just a tad of sheet metal work on it, in addition to all the stuff on the firewall forward:
#1568
#1569
#1570
