2023 Defender 110 Sliders
#21
Brilliant! And looks awesome!! Do you have any pics of the work underneath? Also, did you purchase the Lucky8 sills or did you reinstall the originals? I didn't quite understand which way you went. I think the former, but want to be sure. I'm thinking of going the same route in a couple months and you've inspired me to LineX them first AND to get the step inserts. Final Q, did you think about getting the step insert bolts LineX'd first or could they not guarantee to avoid the threads? Wondering why you decided to paint them afterwards.
Again, very good work and appreciate the photos & responses.
Flynnlax (03-22-2023)
#23
I will get some pictures of the work I did underneath and upload them.
I really like the fact that the Lucky 8 sliders stick out as far as they do, that is a big plus for my trail needs and usefulness as a step.
The sills are the Lucky 8 ones that came with the sliders, I didn't Line-X them because it would be not be a smooth surface and would not allow the door weather stripping to sit flush against it or against the body of the defender. I painted the bolts that hold on the stills, I also used stainless steel riv-nuts for the still, the Lucky 8 riv-nuts were not stainless.
The bolts were not Line-X'ed due to having to install them and that may have damaged the coating on the bolts during installation, I am planning on getting them touched up with Line-X or a DYI bedliner product when I get a chance, but the paint is holding up ok so far, but will definitely will wear off with use. The tread plates are a must have in my eyes, without them I don't think the usability as a step is there especially in wet/muddy conditions. I used all stainless hardware for the treadplates I sourced locally. I used a carriage bolt, it has a smooth rounded head with a square neck underneath that locked into the tread plate while it was being tightened.
I also added stainless washers, lock washers, and nylon lock nuts to the tread plate hardware, and plenty of anti-seize on every nut and bolt for the sliders, still, tread plates, mud flaps, and fiberboards hardware (my hands looked like the tin man after the install). I did not want the stainless hardware to gall when I was tightening everything down and ruin the threads.
#24
The following 5 users liked this post by GCSchmidt:
DefenderSISU (05-01-2023),
GavinC (03-08-2023),
gb1044 (01-04-2023),
mopadzi (01-05-2023),
TrioLRowner (01-05-2023)
#26
Nice work! Thanks for posting all this @GCSchmidt - That line-X is exactly what I was thinking and with the inserts matched they look a ton better - That is the way!. I also agree, those inserts are a must have. The Lucky 8 slider rails stick out enough where one could slip a foot through and get pretty hurt without them. LineX'ing them is a great solution. As for the felt cutting I'm curious how you reused some of the hanging components, I couldn't quite make out the reuse in the photos - Did you drill holes in the underside to re-mount them or just kind of jimmy and bend them into existing holes where you could?
#27
There are a lot of unused riv-nuts on the body that can be used. I did use some of the left over bolts and spring nuts from the heat shield hardware to make my own mounting points to the front skid to attach the fiber boards that lost mounting points because of the skids.
Basically, it was a lot of test fitting, cutting, test fitting, and beer breaks.
#28
I'm really impressed by the work you did to retro-fit the felt boards to fit the spaces left by the sliders.
Have any of you considered the various aftermarket skid plates that are out there as options to replace the felt altogether? I have no idea what they cover vs. what the felt covers - no one really shows a good picture of where the plates fit on the underside.
But I've seen several people selling them:
https://www.devon4x4.com/new-defende...on-system.html
https://www.asfir.com/front-skid-plate-538055.html
https://newdefendermods.com/collecti...ear-diff-guard
https://newdefendermods.com/collecti...ine-bash-plate
safarigardllc on instagram
... and many more.
I'm just wondering if it's possible to replace the felt with a set of metal plates over vulnerable areas that won't interfere with the sliders - won't overlap, expect to use the same mounting holes, etc.
Thanks for any insights you all may have.
... and many more.
#29
... and many more.
... and many more.
#30
... and many more.
... and many more.
https://www.matzker.de/shop/land-rov...chutz-zubehoer
