2023 Defender 130 Sound system
Old Dec 11, 2024 | 03:55 AM
hobadi's Avatar
3rd Gear
Default 2023 Defender 130 Sound system
2023 Defender 130, I am experiencing a problem with the sound system's volume. It suddenly cuts off, although the volume is at the same level. When I turn the volume control up or down, it comes back on again. Dealer can't diagnose it, since it happens randomly and in workshop. Did anyone experience the same, any recommendation?
Old Jun 13, 2025 | 08:14 AM
Cindylgal's Avatar
3rd Gear
Did you ever figure this out? I have a V8 90 Defender 2024 and it has consistently been doing this. It makes a noise like popping and then the radio or Spotify stops playing. I’ve an appointment with Lands Rover next week.
Originally Posted by hobadi
2023 Defender 130, I am experiencing a problem with the sound system's volume. It suddenly cuts off, although the volume is at the same level. When I turn the volume control up or down, it comes back on again. Dealer can't diagnose it, since it happens randomly and in workshop. Did anyone experience the same, any recommendationt?
Old Jun 13, 2025 | 02:58 PM
RogueRover's Avatar
Just seeing this for the 1st time. Early on, our amplifier needed to be rebooted, which required pulling a seat and quarter panel. A year later, the amplifier died and was replaced. It was flaky, intermittent noise, cutting out, etc. The amplifier generates all sounds, to include turn signal clicks.
Diagnosis took the better part of a day by the tech.
Old Jun 13, 2025 | 03:22 PM
Cindylgal's Avatar
3rd Gear
Thanks for the info. Looking forward to seeing what the problem is as it has been happening since I got it intermittently. I forgot to add that if I turn the volume up a fews later it comes back on.
Old Jun 23, 2025 | 06:04 AM
hobadi's Avatar
3rd Gear
Since the issue was occurring intermittently, the dealer couldn't confirm the problem at first. After several attempts, I decided to leave the car at the dealership for a full week until the issue finally occurred. According to them, they replaced the unit. To be fair, the problem has not reappeared since then.
Old Jul 8, 2025 | 04:47 PM
Defender 2020 Madison's Avatar
Default pulled some fuses, now the media infotainment doesn't work
Okay, so I was troubleshooting problem "A", and in doing so, I thought I would check the load space fuses. It was dark and they are hard to read, so I checked them all. I think I made something in the entertainment system get screwed up. Suddenly, I can't select and place the radio. I cannot play spotify on carplay, I can't attach a phone to bluetooth. Everything in the media section, the left on the front display dashboard, doesn't work.
oh, re: the glitches in the sound system, please see the infotainment thread. Our experience is it is glitchy. Check for software updates.
Any ideas?
Thanks,
2020 Defender 110
jilikits994
Apr 17, 2025 01:59 PM
elektron
Oct 20, 2024 08:18 PM
pah4
Aug 30, 2023 01:46 PM
_Allegedly
Jul 1, 2021 05:26 PM
lizglowark
Audio/Visual Electronics
Oct 16, 2011 09:04 AM
