25MM Spacers
Old Jan 13, 2022 | 03:03 PM
mgwally's Avatar
4th Gear
Default 25MM Spacers
Hey Everyone,
Just picked up my 22 Defender S w/ 6010 wheels & off-road tires. I also built the car w/ the extended wheel arches for a more aggressive look. I'm looking to make the stance slightly more aggressive by installing wheels spacers. I've done a bit of research and some of the forum members use mostly 30mm. I personally think 30mm sticks out to much and doesn't look OEM+.
Do you recommend any US retailers that sell 25mm spacers for the new Defender? I can't seem to find anything specific.
Old Jan 13, 2022 | 03:15 PM
Muppetry's Avatar
Originally Posted by mgwally
Hey Everyone,
You think that reducing by 5 mm will make a visible difference?
Old Jan 13, 2022 | 03:16 PM
mgwally's Avatar
4th Gear
Yes I do.
Old Jan 13, 2022 | 06:38 PM
Defendit..'s Avatar
I run 22mm front, 25mm rear, search on this forum...
Anyway here you go:
https://www.tunershop.com/shop/h-r-s...discovery.html
Old Jan 13, 2022 | 07:10 PM
mgwally's Avatar
4th Gear
Anyway here you go:
I ended up finding the part numbers on H&R’s website. That’s the exact setup I ordered. 22mm for the front and 25mm for the rear. Do you happen to have any pictures?
Old Jan 13, 2022 | 07:35 PM
GrouseK9's Avatar
Try these: https://shop.redline360.com/products...gn=sag_organic
Might find them somewhere else cheaper. But they have a wide selection that should fit.
Old Jan 15, 2022 | 03:26 AM
Defendit..'s Avatar
Picture with 18" 6094 255/70 R18 Goodyear AT
Picture with 18" 6093 275/65 R18 Mud Terrains
30mm with the Mud Terrains would be to much, so I'am happy with this set up ( sidenote, you need to shave your original wheelstuds by a few mm for the steelies)
Old Jan 15, 2022 | 07:40 AM
mgwally's Avatar
4th Gear
That looks great! I'm using the tires that shipped w/ OEM off-road package. I'll be posting some before and after pics once i get everything installed.
Old Jan 15, 2022 | 09:05 PM
RR2Dfndr's Avatar
Anyway here you go:
Defendit, did you have to cut or shave off the hub studs for 22mm or 25mm spacers?
Old Jan 16, 2022 | 03:34 AM
Defendit..'s Avatar
I thought I mentioned that
Babadook
Nov 17, 2023 08:38 AM
ElVerde
Dec 12, 2021 12:43 PM
DPReef
Nov 13, 2021 07:07 AM
jringeno
Apr 5, 2017 12:15 AM
GeoA(Atl)07SC
Appearance & Camping Set Ups
Jun 2, 2010 08:29 PM
