Spacers with 18” steel wheels
Old Dec 11, 2021 | 11:28 AM
ElVerde's Avatar
Default Spacers with 18” steel wheels
Has anyone installed spacers on their 18" wheels and can share photos/which spacers they have used?
I have heard varying advice on whether you can use spacers or not, looking for some guidance.
Old Dec 11, 2021 | 03:11 PM
Defendit..'s Avatar
I've done that
https://landroverforums.com/forum/20...21/#post793454
Old Dec 11, 2021 | 07:32 PM
ElVerde's Avatar
Originally Posted by Defendit..
They look great! What spacers did you use and how did you shorten the studs?
Old Dec 12, 2021 | 03:35 AM
Defendit..'s Avatar
I used my grinder with a very thin grinding wheel for removing a few mm of the studs.
Finishing and rounding with a sanding disk on the same grinder low speed.
Stud lenghts are 27 or 28 mm, for my front spacers of 22 mm I removed 4 or 5 mm
for the rear spacers max 3 mm.
Most important is to check if the steel wheels alingn straight to the spacer.
Wheels and spacers are Torqued to 139 Nm as factory specs.
I ​​​​used the H & R spacers, see link
https://www.tunershop.com/shop/h-r-s...scovery-v.html
https://www.tunershop.com/shop/h-r-s...discovery.html
Old Dec 12, 2021 | 05:42 AM
ElVerde's Avatar
Thanks for this! It's lines like this in the item description which give me pause: Using steel wheels in combination with DRM system ist generally not possible!
Is it just a question of alignment?
Old Dec 12, 2021 | 12:43 PM
Defendit..'s Avatar
The orinal studs need to be flat straight/inside with the spacer.
so only for a spacer of 30 mm or wider, no further action is required
see this link, he explains
https://www.google.com/url?sa=t&sour...k9mfdj-yLgQiU6
Babadook
Nov 17, 2023 08:38 AM
Joe!
Apr 24, 2017 09:21 AM
jringeno
Apr 5, 2017 12:15 AM
GeoA(Atl)07SC
Appearance & Camping Set Ups
Jun 2, 2010 08:29 PM
JBeezy53
Jan 20, 2010 10:37 AM
