275/55/20 Spacer Size
Old Nov 27, 2025 | 03:44 PM
goofdunk's Avatar
Default 275/55/20 Spacer Size
Hello,
Just wondering what is the best spacer size without trimming the lugs for the OEM wheel on 275/55/20 with minimal rubbing in access height, I will also be adding the extended wheel arches. Is it 20 in the the front and 25 rear or 25/25 all around?
Thank You!
Old Nov 28, 2025 | 06:37 AM
Defendit..'s Avatar
You can go both.
Or 22 front / 25 rear.
No rubbing with your tire size.
Old Nov 30, 2025 | 12:47 PM
CincyRovers's Avatar
275/55/20 are an OEM size. That is the recommended size for OEM winter tires. If you’re on OEM wheels, you don’t need spacers. They’ll fit perfectly with no rubbing at any height.
more snow
Dec 22, 2025 08:26 AM
Alski19
Feb 2, 2025 07:47 AM
MFESQIDAHO
Jul 20, 2023 10:25 AM
Mi..!
Nov 30, 2022 09:24 AM
