2nd Row Passenger Door wont open
![Angry](https://landroverforums.com/forum/images/icons/icon8.gif)
I have a 2020 Defender 110 SE. At school drop off this morning, my daughter tried to open the 2nd row passenger side door but it would not open as it was locked. I unlocked it, she still couldn't open, then I realized the child lock was on, I removed that and still she could not open the door. I got out and tried to open from the outside, still wouldn't open! I believe the door is stuck or jammed? I turned the car off and on and tried again, all the other doors are working but that one! I cannot get it to serviced until the 20th! I can't drop off my kids if the door wont open. I can't let them out on the other side as there are cars passing on the drivers side of the vehicle.
Any help?
Any help?
The following 2 users liked this post by Ximy82:
AZRadRealtor (06-30-2023),
fahadco80 (06-22-2022)
Any help?
Any help?
Did you figure out how to fix this issue, I have the 2022 SE and I am having the exact same issue multiple times.. and each time I takes it to the dealer it disappears, I have to video record the incident for them to believe me.
Please help if you already fixed it..
Regards
Fahad
Hi,
Did you figure out how to fix this issue, I have the 2022 110 SE P400 and I am having the exact same issue multiple times.. and each time I takes it to the dealer it disappears, I have to video record the incident for them to believe me.
Regards
Fahad
Regards
Fahad
There is a service bulletin on this -- JLRTB02052NAS1
https://static.nhtsa.gov/odi/tsbs/20...80867-0001.pdf
My dealer is ordering the parts and they will replace the mis-sized ones, when they arrive.
I suggest you have the dealer share with you the measurements they take in performing the bulletin.
Enjoy !
Enjoy !
Enjoy !
Enjoy !
Thanks for your reply.
The issue I am having (and I am sure the OP) is totally different issue, it’s something relating to the locking mechanism, the handle itself doesn’t engage either from the inside and the outside, if it’s a sealing issue that surrounds the door, at least the engagement of the handle mechanism can be felt, but what we are having is a loose door handle.
Thanks a gain
FAHAD
I want to share my similar but different issue with the rear door in my ‘22 X Dynamic SE. Upon delivery in November’21, when I arrived home I discovered that when locking the vehicle all doors locked EXCEPT the drivers side rear door. The dealer fixed it the next day, was an actuator in the locking/unlocking mechanism. Others have reported theirs not unlocking, mine wouldn’t lock.
bcolins
06-22-2022 10:37 PM
Paul64
05-22-2007 01:07 PM
marlymarl
07-28-2005 12:23 AM
