ACC activation near Seattle Washington?
#21
#22
Dan,
which of the Gap tools is the correct to purchase. I see the BT which is 440 pounds and the pro is 1600. quite a difference.
i am trying to just deactivate the active noise cancelation and engine noise. I have a v8 and don’t need majority of the other features
did you happen to see those options in the menu?
The IID Tool is still in beta testing at the moment so not all activations are available yet! However if you bought a tool and got in touch with Patrick at GAP Diagnostics he will add you to the beta test, although it may be better to ask first if they are still allowing people to join the beta. As things are worked out more activations will become available, the IID tool has been available for some time and I've used it on my Disco 4's, FF Range Rovers etc, for newer cars they changed the way the system works which is why the tool is still in beta for the Defender. The tool basically plugs into your OBDII port and you control it through either your phone of tablet, as well as activations it also functions as a fully fledged code reader and you can read real time data from the car.
This is a quick video I did for activating the James Bond screen, (it's done in real time so no speeding the video up)
https://youtu.be/p1AbAx162Ak
ficklma1 (07-03-2023)
#23
Mark, I have just started researching activation of ACC and see lots of contradictions. 1) do "all" US L663s have the correct LIDAR and steering wheel switch already installed? I have a 2020 P400 SE. 2) can you share your fee for activating ACC if the hardware is truly all there (understand a drive to LA is necessary)? Thanks - Mike in Seattle area.
#24
Yes all" US L663s have the correct LIDAR and steering wheel switch already installed? I have a 2020 P400 SE.
Yes you have all of the hardware. I can do the software activation. I charge 1000 cash. If I come up to San francisco I can let you know as that would be closer.
Its awesome having it.
drk63
12-07-2022 10:28 PM
