After- Market Lighting on the 110?
Old Jun 6, 2024 | 10:00 AM
  #61
GavinC's Avatar
Originally Posted by b4ll5oh4rd
How is the negative electrode fixed? Thank you
In that picture picture it's on the jump-start ground post. Just unscrew the post and screw it back in with the metal collar on the wiring.
I since moved the ground to a ground point next to the power takeoff. You can see it in the pictures above where I redid the wiring and added a fuse. There are pre threaded ground points there. An M6 bolt of your choice will work. I used one from the underside I had left over following slider installation. Just shortened it a bit with my angle grinder.
Old Jun 6, 2024 | 10:07 AM
  #62
GavinC's Avatar
Originally Posted by GCSchmidt
@gschmitt
Curious to know if the black bolts holding bracket to light have a paint on them or did they come that way? Looking to sleek up my ditch light bolts a bit. something I can brush on would be good.
Old Jun 6, 2024 | 10:38 AM
  #63
GCSchmidt's Avatar
Originally Posted by GavinC
@gschmitt
I painted (brushed) them with semi-gloss black Rust-Oleum after installation, I did use all Stainless Steel anti-tamper hardware as well.
Old Jun 6, 2024 | 05:34 PM
  #64
GavinC's Avatar
Thanks for the info mate. Much appreciated.
ngremion
Defender
Oct 1, 2023 01:58 AM
heliochrome85
Sep 13, 2023 10:46 AM
Jrunr619
May 21, 2023 10:19 AM
MacMia
Jan 21, 2022 11:18 AM
airthirtytwo
Oct 12, 2021 08:00 PM
