Brake Controller
I installed the REDARC Tow-Pro Elite brake controller. You need the REDARC Ford/Lincoln suitable Tow-Pro Brake Controller Harness (TPH-006) as well. That harness will plug into a plug that is attached up the brake pedal. You have to remove the lower dash panel. It’s an easy job. Took me less than 30 minutes. I also used the REDARC Tow Pro Universal Mount. I installed the mount/and **** (controller) in the blank below the parking brake and dimmer.
The following 9 users liked this post by Guapo:
achary27 (03-06-2021),
AUH (03-10-2021),
Cobber (10-07-2020),
Corgi_Express (09-08-2020),
DonMitsu (09-08-2020),
and 4 others liked this post.
Out of the box, the fit is a tad loose, so I used the enclosed foam to tighten things up a bit and finally added some double side 3M tape as well. It looks good and fits well. Other option would have been to drill it out the factory blank.
Huc (09-22-2022)
Take a couple pics on access and how to access the panel, and we can turn this into a DIY thread on the brake controller. I’m going to tackle mine in two weeks!
