Brake Fluid Flush
Old Oct 24, 2022 | 12:16 PM
jarblaz's Avatar
Default Brake Fluid Flush
Hi All,
There is a lot of great information on this forum about the oil changes. Has anyone done the brake fluid flush? I'm assuming we can use the power bleeder and bleed as normal. Also, my dealer is using the BG LV DOT 4 brake fluid. I am planning on using the ATE DOT 4 SL.6 or Pentosin Dot 4 LV which meets all of the specs from LR.
Does anyone have any tips for doing this or better fluids to use?
Old Nov 7, 2022 | 09:18 PM
jarblaz's Avatar
Hi all,
I just completed the brake fluid flush. I didn’t do anything special with the parking brake, just hooked up the power bleeder and opened each bleeder.
I used the following products
Motive Products, European Power Brake Bleeder, 0100, Hand Pump Pressure Tank with Adapter https://a.co/d/1wuSF1p
Genesis Universal 1 Person Brake Bleeder Bottle with a Stainless Steel Cable Mount and 12 Inch Fluid Tube https://a.co/d/3gfOz9X
https://www.fcpeuro.com/products/sl6...-liter-ate-sl6
Old Nov 8, 2022 | 05:53 AM
MattF's Avatar
Thanks for this. How much brake fluid did it requre?
Matt
Old Nov 8, 2022 | 07:52 AM
jarblaz's Avatar
Matt
I went overkill and used a full liter. It probably didn’t need that much.
I did use a turkey baster to suck the old fluid out of the reservoir first. I would use a large syringe if I did it again. The turkey baster drips fluid and is messy.
HORUSDY 200cc Fluid Extractor, Oil Extractor/Oil Syringe, Fluid Syringe Pump Manual Suction Vacuum Fuel Car Transfer https://a.co/d/g5WCw5C
Old Nov 8, 2022 | 09:08 AM
GavinC's Avatar
Originally Posted by jarblaz
Hi all,
Good info
I have a brake bleeder but it's the kind where you hook it up and pump the brakes to flush the fluid. Any problems doing it without a power bleeder do you think?
Attached Thumbnails Brake Fluid Flush-all11017-brake-bleeder-bottle-magnetic-mount-check-valve-plastic-tubing.png
Old Nov 8, 2022 | 09:24 AM
jarblaz's Avatar
That's a good question. I would think that would work, but I haven't tried it. The service manual says to use a pressure bleeder, but is also says you have to use the LR computer to put the brakes in assembly mode so....
https://www.lrdefender.org/brake_sys...liper-514.html
Old Nov 8, 2022 | 09:44 AM
Ericlockheed's Avatar
I recommend disconnecting the battery.
in failsafe mode, you can pump the brakes like a manual braking system.
Im not a professional do so at your own risk
Old Nov 8, 2022 | 10:20 AM
GrouseK9's Avatar
I'm seriously hoping someone puts together a brake bleed video before I need to do it! I've done them before, but like the Defender oil change vids, I love them.
Old Nov 8, 2022 | 10:29 AM
jarblaz's Avatar
I should have done a video, but it is really simple with the tools I showed above.
1. Suck out the old fluid from the reservoir
2. Refill with new fluid
3. Fill the power bleeder with fluid and attach to the master cylinder
4. Pump up the power bleeder to about 15 psi and watch for leaks
5. Clean around the bleeder screw
6. Attach your catch bottle to the bleeder screw
According to the manual it is left rear, left front, right front, right rear in that order.
7. Open the bleeder screw about 1/4 turn and watch fluid drain. I let the most out of the left rear because it was the furthest.
8. Close the screw
9. Repeat 6-8 for each corner checking the fluid level in the master cylinder and pressure bleeder in between each. Pump back up to 15 psi after each corner.
I was super paranoid about running dry so I closed them several times and checked the pressure and fluid levels.
Old Nov 8, 2022 | 10:47 AM
Kev M's Avatar
According to the manual it is left rear, left front, right front, left rear in that order.
You said "left rear" twice, did you mean "right rear" the second time?!?
